Below is code for a programme i was mucking around with
basically using timers to flash led's on/off instead of loops
however anychip i burn the code too it prevents further erasing/reprogramming
i have tried 5 chips all with the same result - they are 16f628a / 16f648a
below is my code
i would like to know what the problem is that it 'kills' chips?????
Also how do i fix the code and how do ifix the chips if possible????
Many thanks
noel
;16f628A pin connections
; ra2 | | ra1 - output
; ra3 | | ra0 - output
; ra4 | | ra7
; ra5 | | ra6
; ground | | Supply
; rb0 | | rb7
; rb1 | | rb6
; rb2 | | rb5
; rb3 | | rb4
#DEFINE BANK0 BCF STATUS,5 ; define STATUS register bit 5 clear as BANK0
#DEFINE BANK1 BSF STATUS,5 ; define STATUS register bit 5 set as BANK1
#DEFINE T01F INTCON,2
#define T01E INTCON,5
#define TIMEROFF bcf T1CON,0
#define TIMERON bsf T1CON,0
list p=16f628a ; tell MPASM-type programmer to create a
; list (LST) file
include p16f628.inc ; bring in all standard register values
CBLOCK h'20'
BRIGHTNESS
ENDC
__config 0x3F18 ; internal 4MHz oscillator
ORG 0 ; reset vector
goto STARTIT
ORG 4 ;Interrupt Vector Address
;if an interrupt occurs the CPU will
;be directed to address $0004
;when the PIC is in programming mode it sets its
;internal counter to $0000 which is the reset
;vector address.The writer of the TASM
;programming toolkit decided to have
;it set this internal counter to $0005
;Thus .ORG $0004 must be used at the
;start of all TASM programs.
;Addresses $0001 to $0003 are not used with TASM
goto STARTIT
ORG 5 ; PIC program memory location at which to start
goto STARTIT
STARTIT BANK0
clrf PORTA ; clear PORTA's output if any
clrf PORTB ; clear PORTB's output if any
movlw 0x07 ; needed by some PICs, including PIC16F628
movwf CMCON ; so that PORTA is treated as digital port
BANK1
movlw b'00000000' ; all PORTA as output
movwf TRISA ; data direction register for PORTA
movlw b'00000000' ; PORTB as output
movwf TRISB ; data direction register for PORTB
bsf PIE1,0 ;enable interrupts
BANK0
movlw b'01111011' ; using compare tr2
movwf T2CON
movlw b'00111100'
movwf T1CON
movlw b'00001111'
movwf CCPR1L
movlw b'00001010'
movwf CCP1CON
;CLRWDT
movlw b'00000010'
movwf PORTA
goto LOOP
DELAY TIMEROFF
movlw 0xaa
movwf TMR1H
movwf TMR1L
bsf INTCON,6
bcf PIR1,0
TIMERON
btfsc PIR1,0
goto $+2
goto $-2
bcf PIR1,0
movlw b'00000001'
xorwf PORTA,f
return
LOOP bsf PORTA,3
call DELAY
bcf PORTA,3
call DELAY
goto LOOP
NOMORE goto NOMORE
END
below is my code
Many thanks
noel
; ra4 | | ra7
; ra5 | | ra6
; ground | | Supply
; rb0 | | rb7
; rb1 | | rb6
; rb2 | | rb5
; rb3 | | rb4
; list (LST) file
CBLOCK h'20'
BRIGHTNESS
ENDC
goto STARTIT
goto STARTIT
goto STARTIT
STARTIT BANK0
BANK1
BANK0
movwf T2CON
movlw b'00111100'
movwf T1CON
movlw b'00001111'
movwf CCPR1L
movlw b'00001010'
movwf CCP1CON
;CLRWDT
movlw b'00000010'
movwf PORTA
goto LOOP
DELAY TIMEROFF
movlw 0xaa
movwf TMR1H
movwf TMR1L
bsf INTCON,6
bcf PIR1,0
TIMERON
btfsc PIR1,0
goto $+2
goto $-2
bcf PIR1,0
movlw b'00000001'
xorwf PORTA,f
return
LOOP bsf PORTA,3
call DELAY
bcf PORTA,3
call DELAY
goto LOOP
NOMORE goto NOMORE
END
