fifahaywire
i made a buck converter for an LED driver and i tried different types of output capacitors and found out that if i use the one on the right (refer picture), the LED will start to dim out on it's own even when i didn't off the supply, while if i use the one on the left (it's the blue one, polyester capacitor), the LED will light up like normal and turn off only after few seconds i turn off the power supply. why is this so?
also this website show the blue capacitor i'm using **broken link removed**
actually i'd prefer to use a smaller size capacitor (other than electrolytic) that is the reason why i tried the one on the right. but apparently the output isn't what i want. and just to add in, i did put in a current limiting resistor in series with the LEDs (just in case if it's the reason why but i'm not aware of it )
please advice
please advice
