Choosing a MOSFET driver for H-bridge on mouser.com
I'm attempting to put together a speed controller for a hobby RC brushless DC motor. The power source will be 12V and max current should be less than 20A. I'll probably use a PWM frequency of 10kHz from a PIC uC.
With my limited understanding so far, I've chosen this MOSFET to form the h-bridge. So now I'm trying to pick out a MOSFET driver that is up for the task. I think I understand the need for high-side and low-side drivers. Namely, the high-side driver needs to provide 10V at the gate above the 12V source, while the low-side only needs to provide 10V at the gate.
The problem is, I only found low-side drivers on mouser.com. I filtered for through-hole components, as I wanted to build this on a breadboard. There were several DIP packages for low-side MOSFET drivers, but no high-side. I think the one device that was a combined high and low side driver was out of stock.
Am I going about this wrong? I would have figured the market would have tons of DIP package drivers to drive h-bridges. Any recommendations for an alternative approach would be greatly appreciated.
Thanks,
Dan
Thanks,
Dan
