I glued some expensive parts (piezos) together with a steel laden epoxy resin, I've separated the parts ok but how do I get rid of the epoxy resin? I think I need some kind of chemical or 'wet' solution. If all else fails I will try sanding the epoxy off but I'd prefer to avoid that if you can think of a better solution.
I also need to remove excess solder very cleanly from the same parts. I have got most of it off but the rest is in a very thin layer. What would you suggest?
