Clock speed error 18LF2520
camerart
Can someone put this through the Oshonsoft SIM, please. I can't get the Start up LEDs to flash at 1 sec ON/OFF.
Thanks.
Camerart
  • 18LF2520 INT4MHz SIMPLE SERVO LOOP 160618 1700.bas
Thanks.
Camerart
If you are using the internal oscillator, then you have to set the frequency to 4Mhz in OSCCON register.
Define clock_frequency = 4 only tells the compiler what the frequency is to be used in waitus, waitms delays, not to set it.
