Code changes needed to convert 240V/50Hz to 110V/60
skeeterb
C:
const unsigned char DutyCycleValues[50]= {0, 8, 16, 24, 31, 39, 47, 55, 62, 70, 77, 85, 92, 99, 106, 113, 120, 127, 134, 141, 147, 153, 159, 165, 171, 177, 182, 188, 193, 198, 202, 207, 211, 215, 219, 223, 226, 229, 232, 235, 238, 240, 242, 244, 246, 247, 248, 249, 250, 250};
unsigned short cnt,inc,dec,cnt1;
void interrupt()
if (dec==0)
   {cnt++;
    PWM1_Set_Duty(DutyCycleValues[cnt]);
else if (dec==1)
    {cnt--;
     PWM1_Set_Duty(DutyCycleValues [cnt]);
TMR1IF_bit = 0; // clear TMR0IF
TMR1H = 0xFF; // Initialize Timer1 register
TMR1L = 0x76;
void main()
TRISB = 0; // designate PORTB pins as output
PORTC = 0; // set PORTC to 0 PORTB = 0; //
set PORTC to 0 TRISC = 0; // designate PORTC pins as output
TRISA = 0; // designate PORTB pins as output
PORTA = 0; // set PORTC to 0
T1CON= 0b00000001; // Timer1 settings
TMR1IF_bit = 0; // clear TMR1IF
TMR1L = 0x76; TMR1IE_bit = 1; // enable Timer1 interrupT
cnt = 0; // initialize cnt cnt1=0;
inc=0; dec=0; PWM1_Init(20000); // Initialize PWM1 module at 20KHz \
PWM1_Set_Duty(0); PWM1_Start(); // start PWM1
PWM2_Init(20000); // Initialize PWM2 module at 20KHz \
PWM2_Set_Duty(0);
PWM2_Start(); // start PWM2
INTCON = 0xC0; // Set GIE, PEIE PORTA.b0=1;
while (1) { // endless loop
     if (cnt==49 && dec==0)
        { dec=1;
     else if (cnt==0 &&dec==1) {
PORTB.B1 = 0; PORTB.B2 = 1;
PORTB.B1 =~PORTB.B1;
PORTB.B2 =~PORTB.B2;
dec=0;
}[CODE]
In the attached PDF file, it talks about building an inverter that inverts 12VDC from solar panels to the 240/50Hz AC needed to power household items. What bits of the attached code would have to be changed to make it 110V/60Hz that we use here in the US?
  • LOW DISTORTION SINE WAVE INVERTER FOR HOUSE BACKUP.pdf
Instead of 20 kHz, you would want 24 kHz. Anyway 24/20*50=60; Not how I arrived at the number.
There probably should be an output filter, so those component values should be changed slightly. Part of the schematic seems missing.
Would the duty cycle list at the beginning of the code have to be changed in order to get the 24KHz frequency? I noticed on looking further through the file that I have attached, that some components would have to be replaced as well in order to get the right frequencies through the system to drive the H-Bridge at 60Hz.
