How to change this code to work for 16f88
; Program "LCD.ASM"
title "LCD"
processor 16F84a
include p16f84a.inc
__config _PWRTE_OFF & _WDT_OFF & _XT_OSC
radix DEC
errorlevel -302
#define E PORTB,3
#define RS PORTB,2
#define DATA_PORT PORTB ; Only of RB7 … RB4
#define DATA_DIR TRISB
cblock h'0C'
SaveW
Char
Temp
Temp1
Temp2
Temp3
Temp4
Result : 4 ; MSB first
Thousand : 2 ; MSB first
BCD0
BCD1
BCD2
BCD3
N
endc
org 0
goto START
ClearDisp macro
movlw b'00000001'
call SEND_CMD
call T1mS ; To erase the screen takes more 1mS
endm
DataOk macro ; Validation of the data
bsf E
bcf E
endm
DDRam macro address
movlw 0x80 + address
call SEND_CMD
endm
Disp macro charvalue
movlw charvalue
call SEND_CHAR
endm
RSCmd macro ; The data are orders (RS=0)
bcf RS
endm
RSChar macro ; The data are characters (RS=1)
bsf RS
endm
ShiftL macro ; Decalage towards the left of posting
movlw b'00011000'
call SEND_CMD
endm
;________________________________Subroutines________________________________
; Delays 1mS, 10mS, 100mS and 1S
T1mS
movwf SaveW
movlw .248
movwf Temp1
Loop1mS
nop
decfsz Temp1,f
goto Loop1mS
movf SaveW,w
return
T10mS
movwf SaveW
movlw .10
movwf Temp2
Loop10mS
call T1mS
decfsz Temp2,f
goto Loop10mS
movf SaveW,w
return
T100mS
movwf SaveW
movlw .100
movwf Temp3
Loop100mS
call T1mS
decfsz Temp3,f
goto Loop100mS
movf SaveW,w
return
T1S
movwf SaveW
movlw .100
movwf Temp4
Loop1S
call T10mS
decfsz Temp4,f
goto Loop1S
movf SaveW,w
; Description: Transmet un caractere vers l'afficheur
; Entr‚e: Caractere dans le registre W
; Sortie: Aucune
SEND_CHAR
call T1mS ; Attendre que l'afficheur soit pret
RSChar ; Afficheur en mode caract‚re
movwf Char ; Sauvegarde du caract‚re
movf DATA_PORT,w
andlw 0x0F
movwf DATA_PORT
; Masquage: Reset du poids fort de DP
movf Char,W ; On restaure le caract‚re dans W
andlw 0xF0 ; On isole le poids fort du registre W
iorwf DATA_PORT,F ; On positionne le poids fort de DATA_PORT
DataOk ; On bascule le verrou du LCD
swapf Char,F ; On ‚change les poids fort et faible
movf DATA_PORT,w
andlw 0x0F
movwf DATA_PORT
movf Char,W
retlw 0 ; Retour avec W=0
; Description: Transmet une commande vers l'afficheur
; Entree: Commande dans le registre W
; Sortie: Aucune
SEND_CMD
call T1mS ; Attendre que l'afficheur soit prˆt
RSCmd ; Afficheur en mode commande
movwf Char ; Sauvegarde de la commande
movf DATA_PORT,w
andlw 0x0F
movwf DATA_PORT
movf Char,W ; On restaure la commande dans W
movf DATA_PORT,w
andlw 0x0F
movwf DATA_PORT
movf Char,W
;____________________________________main___________________________________
START
bsf STATUS,RP0
movlw B'00000000'
movwf TRISB
bcf STATUS,RP0
clrf PORTB
call INIT_LCD
movlw b'00001100'
call SEND_CMD
movlw b'00101000'
call SEND_CMD
ClearDisp
Disp 'F'
Disp 'R'
Disp 'E'
call T1S
ClearDisp
end
