code help?
nabil13
my hardware is :
sensor(LM35)>external ADC(0808)>pic(16f877a)>pc
i do not know how to start the pic program, can any one guide me...
Do you need to use the external ADC? The PIC you have chosen has a built-in 10 bit converter which seems better than an ADC0808. Both are 8-channel.
is excellent and covers how to do this with the 877.
my hardware is :
You need to understand how to do each line of the following. Start with the datasheets. If you are using a compiler read the manual that talks about the libraries you will be using.
start:
   setup PIC IO ports
   setup ADC
   setup UART
   etc...
loop:
   read ADC
   calculate temperature based on above reading
   fomat string with temperature data
   output string to UART
   goto LOOP
It's presumably a school assignment, it looks like India (which I'm guessing is the area where he's from?) is trying to move a bit more modern, but have simply crossed out the antique processor in the old question, and replaced it with PIC.
He's the second one with such a silly request.
