jimlovell777
I'm working on a project to receive raw caller id data from a MT8841 IC and send it to a computer via RS-232 serial port using a MAX232. I need to send the caller id data in a special format. I need to implement the caller id data parsing in C so I can run it on the PIC micro. I have a general out line of what needs to happen and detailed specs of the incoming data but I lack the ability to code it. The specs can be found here http://www.geocities.com/jimlovell777/cid.txt I just need to extract the caller name, caller number and date time to be stored in three variable arrays so i can send them to the computer. Any solution of help would be very useful to me. I can try coding it if someone can just help me where I'm stuck, if someone wants to code it for me instead of taking the time to try to explain it to me then ok, I really mean anything would be a help. If someone would be willing to work with me to finish this project I'd be very grateful. Thanks for reading.
