coding
value is stored in a register..
i am using 4 bit of port 2 to interface with 4 bit encoder.
suppose value is in reg. R0
then..
mov p2, R0;
how can i give a decimal no to port 2
can you explain. plz
Explain what? It's just a code snippit, not a complete program. The first line sends the lower 4 bits, second line places the upper 4 bits in the lower portion, and third line sends the newly placed for bits. So, for example, for 53H, it sends the "3" and then the "5". Sending Decimal 83 doesn't solve you problem.
then..
mov p2, R0;
In that case, you do
mov p2, R0
then you shift the value of R0, using whatever shift instruction you have, for example
SR R0
SR R0
SR R0
SR R0
Where SR is a "shift right" instruction.
then do mov p2, R0 again.
You can also do a divide by 16 instruction in place of the SR instructions.
