Coil Impedance
codan
I was reading about Impedance & it says impedance, describes a measure of opposition to a sinusoidal alternating current (AC).
Sinusoidal meaning sine wave i guess.
What i was wondering is, does that apply also to a square wave source to pulse a coil?
If so would someone have the equation to calculate the impedance of a coil from Frequency & Inductance.
Thank You
Thank You
A square wave is made up of an infinite number of odd harmonic sine waves. [ inc the fundamental]
Sine Wave, Square Wave and Fourier
So you could analyse the effect of an inductor on say the fundamental and first 5 odd hamonics of a square wave.
EDIT:
as you are Spice user, why dont you sim this.??
The only insight that I could offer is that the sine wave, if pure and undistorted (or relatively so) is one frequency. A square wave might be described as being quite the opposite if you were to break it down across the spectrum. I don't know if there is sufficient power at non-fundamental frequencies of a square wave to interfere with your measurements.
Thanks again Eric & stevez,
Eric:
Yep, i will sim this once i learn how to get past "open file" with Spice haha!
Does this seem correct for the impedance of an Inductor:
Xl= 2*pi*F*L
Eric:
Xl= 2*pi*F*L
yes, impedance.
Do you want an *asc starter file for this inductor.?
"Do you want an *asc starter file for this inductor.? "
Eric, you will have to excuse my ignorance on this but i guess it's an inductor file for spice, if so then sure, it would be good.
Just run the *.asc file using Spice.
  • Ind2a.asc
