chriselias272
Hi all,
I'm new here and hope you can help.
I'm planning on using 16 Cold Cathodes (8 inverters - 2 cathodes of each inverter, from ebuyer.com) to light an area in a kitchen.
To power them, i need a 12vDC supply. i've thought that a scalextric power supply would be ideal, however when i tested one last night, the inverter blew after about 10minutes. Everything looked find until then.
I only had on cathode plugged in to the inverter though, would this be the reason? or do i need some kind of resistor or capacitor before the inverter? Are there any tests i can do to check voltage etc?
This is probably a real easy one for you guys but i don't want to risk plugging all 16 cathodes in to find that they blow within 10minutes.
Any help appreciated.
