Colpitts oscillator !!! frequency mistake ?
majd-ghadab
Hello everyone I have faced very strange thing that calpp oscillator (Colpitts oscillator) have different frequency from formulas and big different !
I have used 100uH inductor which I measured its value 100% with inductance meter (and I bought it not made it)
Any way the idea is I always got a frequency about 2.6 MHz and smaller depending on capacitors values , with tow 39pF capacitors and 100uH inductor I must get around 3.6 MHz but I get 2.6 MHz with any capacitors values even with 2pF in other words I have removed the tow capacitors from the oscillator and the circuit still oscillating with 2.6 MHz !!!!!!!!
I can get higher frequency with different inductor only !
You can see real pictures circuit with oscilloscope and the simulated on multisim witch its results is very close to theoretical formulas.
  • cir.zip
If you attach your files as simple jpg or similar, I will have a look.
I will not mess around unzipping unknown files.
i have solved the problem there is an affect called "parasitic parallel capacitance" with this RF Choke and now after changing the inductor type the problem solved
