User276354
I have a heater like this,
The timer dial was broken, so I opened up the heater, eliminated the dial from the wiring, and tested it. Unfortunately there was some voltage registering at some places I didn't expect. I labelled the following diagram:
F is the component no longer included. C is a tipping-switch, working fine. The dial-thermostat at E is working fine, the safety-thermostat at G is working fine. But at D, there is a voltage at the side of the brown wire. It should be 0, but it isn't. D is a switch, giving 0, 1,2,3 as settings (see first piccy). When this switch is set to 0, voltage at the brown wire connection to D is about 50V, but i thought it should be zero. When the switch is set to 1, 2, or 3, the voltage at the brown wire reduces to about 23 volts. BTW, I live in a 240 V country and the input voltage seems to measure fine. Whatever voltage I read at the junction between D and the brown wire shows up also at A (the earth wire).
Here is a close-up of the switch.
I thought that any voltage appearing at earth was a problem.
There is one possible complication: many of the appliances in my house have 'live' casings, because I live in a dodgy country with very lows standards in electrics (Egypt). For example, the macbook pro I am using right now , when I rest my hands on the keyboard, is generally around 20-50v (so I use a wireless keyboard!). But it's not usually a problem unless I take my shoes off.
But I didn't think this could be the full explanation, since the voltage to the heater measures zero all the way from the entry (B), through the tip-switch and thermostat; it is only at the switch (D) that voltage seems to be 'lost'.
Any ideas?
tim
![7wnEUs0.jpg](https://i.imgur.com/7wnEUs0.jpg)
![JVrdw66.jpg](https://i.imgur.com/JVrdw66.jpg)
![Lo1F2ij.jpg](https://i.imgur.com/Lo1F2ij.jpg)
Any ideas?
tim
