Mine are quite happy at 19200 for the bootloader and 56,000 (ish) for the programmer.Nigel Goodwin said:Depending exactly what it's doing, they generally work well - maximum throughput is usually only 9600 baud or so though. I've actually got a Belkin one connected to this very computer.
picbits said:Mine are quite happy at 19200 for the bootloader and 56,000 (ish) for the programmer.
I use them for just about anything that doesn't require too many I/Osblueroomelectronics said:I've used a PL2303 with my ICD2 clone.
PS picbits what are you using the PIC18F1320 for? I'm asking as it's the PIC I chose for my next kit (Junebug)
Sceadwian said:Nigel, most serial to USB converters will buffer data for USB transfer, and won't send it just a byte at a time, depends on the program accessing the com port and the chip in the converter though. I've seen chips rated at a megabaud for buffered transfers.
Sceadwian said:I can't check the Elektor results you mentioned because I won't register to every website for individual articles I'm interested in.
