Command not recognised in Oshon IDE
Ian Walters
Hi
I'm very much a novice with microchips / programming and my sole interest is using them for simple robotice animation of models.
I've been using an evaluation copy of Proton IDE so far but now want to write a program longer than this will allow so I bought a copy of PIC16 from Oshon. The models are actuated by a push switch so in Proton I've been using the IF / THEN command string.
The problem I've got is that in Proton I use the command "nop" (no operation) to instruct the chip to do nothing if the switch is low before returning to the Main command, however in PIC16 this "nop" is not recognised and I can't find an alternative syntax to use!
An help or suggestions would be very welcome!
Best regards
For example, if the switch is connected to PORTA bit0
While PORTA.0=0
Wend
or
loop:
if PORTA.0=0 then goto loop
in proton basic i think the NOP command is used like this ;
ASM
nop
nop
nop
nop
nop
nop
nop
nop
ENDASM
For Oshon PIC basic it is used like this ;
ASM: NOP
ASM: NOP
ASM: NOP
ASM: NOP
ASM: NOP
ASM: NOP
ASM: NOP
ASM: NOP
Is this what you mean.
Hi Gentlemen
I'm doing something wrong here? I tried all these suggestions but none of them were recognised!
This is what I have written:
TRISB = 0
TRISA = 1
Symbol switch = PORTA.3
Symbol led2 = PORTB.4
Symbol led1 = PORTB.3
Symbol schip = PORTB.5
Symbol theatre = PORTB.1
Symbol fan = PORTB.2
main:
While PORTA.3 = 0
Wend
start:
All I want to do is to get the program to start when the switch on PORTA.3 is pressed making it high but Oshon doesn't recognise this?
I've tried other variations including the IF, THEN, ELSE and ENDIF commands but Oshon seems blind to them? eg
If switch = 1 then
Goto start
Else
goto main
Endif
(Can anyone quote me the correct syntax for this string?)
I'm very much a "newbie" at programming PIC chips with BASIC and am using it to animate scale models so my knowledge is limited to "need to know". I would be very grateful to anyone who can advise on this?
PS please write slowly and use little words!
Thanking you in advance
Which PIC type?
Post your full code, use the INSERT/CODE in the reply on the menu bar.
E
If switch = 1 then
Goto start
Else
goto main
Endif
Nothing wrong here..... What is the compiler complaining about...
Just compiled this in Oshonsoft with no issues at all
TRISB = 0
TRISA = 1
main:
While PORTA.3 = 0
Wend
start:
If switch = 1 Then
   Goto start
Else
   Goto main
Endif
End
Try this, it works for me.
AllDigital
TRISB = 0
TRISA = %00001000
main:
While PORTA.3 = 0
Wend
start:
Toggle PORTB.7  'test ONLY
If switch = 1 Then
Goto start
Else
Goto main
Endif
His main problem was as follows.
... Alldigital' missing
so PORTA was as Analog default
TRISB = 0
TRISA = 1 ' Only PORTA.1 set as Input [ but not used in program]
Symbol switch = PORTA.3 ' he has PORTA.3 TRISed as Output
main:
While PORTA.3 = 0' Output pin!
Wend
start:
If switch = 1 then ' it was an Output pin!
Goto start
Else
goto main
Endif
Hi Gents
Copied the code and pasted it in, it compiles and loads and the PIC runs perfectly!
Very, very many thanks, I think I now understand what I was doing wrong. Still an awful lot to learn but progressing slowly and really appreciate the time and effort you folks put into this forum.
Best regards
