littletransistor
Hey there,
Currently I'm using the PIC18F4221 which is used as the brains of the HD-44780-based alarm clock, with the DS1307+ RTC running. However, the 4K space had been used up, so I intend to replace the PIC18F4221 with the PIC18F45K20. (checked the datasheets - almost the same, except the memory space is more)
The thing is, this microcontroller uses 3.3V, while the rest of the stuff uses at least 5V for normal operation.
Could they be compatible? Or should I use a 3.3V voltage regulator, and then connect the output to the Vdd of the chip?![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
