Communicator
wizard
the below link is about making a 'laser communicator':
Chapter 7: Light and Optics
After looking at it, I thought, now that i am playing with ultrasonics so it is better to go and do the same job with ultrasonics sensors.
Wanted to know if it is possible to transmit a 1.5khZ beep sound via an ultrasonic sensor(40kHz)? My sensor's bandwidth is almost 3kHz so there would not be any problem caused by bandwidth for that 1.5 kHz signal. I want to send it by the the T sensor and then receive it by R sensor and finally hear that 1.5kHz by a headphone.
The problem is that I don't know the ways to do so?
Thanks for any help.
The only way I know is modulating that 1.5kHz signal with a 40kHz as based frequency and then demodulate it in the receiver(i.e R sensor circuitry)
Do you know another way doing the job?
which kind of modulation is the best to go for?
FM modulation is best but is difficult.
AM modulation is easy but is affected by imterference.
The light comm unit will have better distance. Usonic is very limited in range. You could just yell, "Hey you" with as good range.
According to FM don't you think a chip is able to do it easily?
So why it would be difficult?
What do you mean by interference? Interference with what?
Do you think the only way is 'modulation' like I do?
For AM do I need a certain chip modulator? or a transformer will do it for me(like the link)
I know that light is much better but I like to do it to learn more and more.
I have done it by 'light', 'electromagnetics(FM transmitters)' and now like to do it by 'mechanical' waves(i.e ultrasound).
An AM detector is just a diode and a small capacitor. But flashes of light and bursts of IR (sunlight) cause interference with IR AM.
An FM detector is the phase detector of a CD4046 phase-locked-loop IC.
An AM modulator is a simple transformer or a transistor.
An FM modulator is a voltage-controlled-oscillator in a CD4046 phase-locked -loop IC.
