Hello,
I cannot seem to make it work..
I have a voltage comparator (LM301),
I insert to (both) its inputs varying voltages,
and I am assuming that every time (and for as long as) the + input has a greater voltage than -input,
the comparator should trigger a pulse (of variable duration in accordance to differential input) that goes from 0 volts to "supply voltage" volts (9V in my case, I am using a dual voltage supply made with batteries).
The input(s) is filtered-low-frequency-audio content.
So, assuming the input (audio, i.e 100Hz) has an envelope duration of 20ms, the pulse's duration should be (in theory-works also in workbench) about 4ms.
But instead of having a pulse at LM301 output, I have a very low signal there (maybe less than millivolts) that looks more like a triangle waveform and less like a pulse.
Can u tell what is wrong..??
I am suspecting that differential input is very low, could that be the case..??
Many thanks in advance,
xmat.
xmat.
