Some comparators have a output enable pin, which basically puts the output into a tri-state condition. If that is what you are looking for?
https://www.electro-tech-online.com/custompdfs/2010/09/tl712-1.pdf
> is there a way to make them have a dead zone
It's called a window comparator, you make that with 2 comparators. It has 3 outputs : above window, below window, inside window.
is the solartracker circuit for use w/ a controler? cause i'm not able to use them as of yet![]()
