Compass module and pic asm code
AGCB
I've searched this forum and the web in general but can't seem to find any examples of PIC asm code for the Honeywell 3 axis compass module. I'm just getting started with this chip and the only code that's readily available is for the basic stamp. Just looking for some snippets or code segments. I use 18F but can convert from 16F. If you've done something yourself or seen something, please let me know.
Thanks, Aaron
Thanks. That is a nice little chip.
The interface is apparently I2C. You will be reading two, 8-bit numbers and then doing what ever you need to them. Awhile back, I put up a blog in which I read an accelerometer's 16-bit data, and then used a table to calculate what I wanted (inclination). I did not deal with an I2C, and obviously, it is not exactly what you are doing. But, it is in MPASM, if that helps. Here's the link: https://www.electro-tech-online.com/blog-entries/memsic-inclinometer-assembly-language.254/ (NB: The links to Memsic don't work anymore, at least not when I last tried them.) Parallax sells a similar device based on a Memsic accelerometer
John
Edit: Also noted some of the special characters are screwed up in the blog post, but the content is probably still clear. I give a reference to the Parallax device therein.
John
Thanks John. I'll study that out and see if I can figure it out.
Aaron
Post deleted so as not to confuse anyone or waste their time. See posts hear after. Thanks. Aaron
I've made progress this morning!
I removed the restart and pointing to next register in the compass plus some cleanup and am now getting X, Y, and Z numbers on the LCD And it keeps looping w/o stopping!
Latest code
;================ Main loop==================================
Main
    call    hello
    call    beep
    call    del_1s
    call    lcd_clr
read    ;loop
    btg    porta,5
    call    READ_COMPASS
    movff    XHI,numh
    movff    XLO,numl
    putstr    "X =  "
    call    convert
    call    LCD_Decimal
    call    Del_2S
    call    lcd_clr
    putstr    "Z =  "
    movff    ZHI,numh
    movff    ZLO,numl
    call    convert
    call    LCD_Decimal
    call    Del_2S
    call    lcd_clr
    putstr    "Y =  "
    movff    YHI,numh
    movff    YLO,numl
    call    convert
    call    LCD_Decimal
    call    Del_2S
    call    lcd_clr
    goto    read
READ_COMPASS        ;SINGLE-Measurement mode
    call    beep
    call    s_start
    MOVLW    slave_write            ;0x3c  control in (write)
    CALL    send_i2c_byte
    call    chk_ack
    movlw    0x02        ;Mode register
    call    send_i2c_byte
    call    CHK_ACK
    movlw    0x01        ;(single-measurement mode)
    call    send_i2c_byte
    call    CHK_ACK
    delaycy (100*msecs)
    call    s_restart
    movlw    slave_write            ;0x3c  control in (write)
    call    send_i2c_byte
    call    chk_ack
;read Xhi
    movlw    XHIREG        ;point to XHI register
    call    send_i2c_byte
    call    CHK_ACK
;restart and send control byte (READ)
    call    s_restart
    movlw    slave_read            ;0x3d  control out (read)
    call    SEND_I2C_BYTE
    call    chk_ack
;Configure MSSP for reading
    bsf    sspcon2,rcen        ;enable i2c read
    call    waitMSSP        ;waits for the last I2C operation to complete
    bcf    sspcon2,ackdt
    bsf    sspcon2,acken        ;send ack to slave
    movff    sspbuf,XHI
    delaycy (10*msecs)
    bcf    sspcon2,ackdt
;    bsf    porta,1
    movff    sspbuf,XLO
;read ZHI
    delaycy (10*msecs)
    bcf    sspcon2,ackdt
    movff    sspbuf,ZHI
;read ZLO
    delaycy (10*msecs)
    bcf    sspcon2,ackdt
    movff    sspbuf,ZLO
;read YHI
    delaycy (10*msecs)
    bcf    sspcon2,ackdt
    movff    sspbuf,YHI
    movff    sspbuf,YLO
    call    S_STOP
    return
The compass data sheet says that the x, y and z values are 16 bit values in 2s compliment. I'm using a convert routine which takes a hi 8 bit value and a lo 8 bit value and converts them to a 5 digit decimal. This may not be what is needed. What is a "16 bit value in 2s compliment" ?
The X value is either 0 or 65535 , the Z value changes as the compass is rotated and the Y value is always 65535.
Aaron
I looked into google on 2s compliment. I now know that my previous calcs were wrong and that it will take much more study. Taking shop math in high school allowed me to learn much more as an adult/old fart.I'll be back soon! Aaron
IS this right?
To convert a 16 bit 2s compliment to 2 8 bit binarys
After determining sign, complment both Msb and Lsb, add 1 to Lsb and if there is a carry add 1 to Msb, convert to hex or decimal and put in sign.
Sound good?
