Keruskerfuerst
What is the best way to compensate the overshooting of an audio op amp (like BB OPA 627 or 134PA)?
Hardwire said:There isn't much overshoot in an op amp unless you are driving capacitive loads. Is that what you mean?
I guess what I mean is that there isn't much inherent overshoot to most op amps (right?) Step a voltage into a non-inverting opamp and there won't really be any overshoot at all, right?Optikon said:Not true. Many cases can cause overshoot. Capacitive loads working on output impedance of amplifier to create a feedback pole are only ONE example.
Keruskerfuerst said:In case of inverting and non-inverting opamp, the datasheet tells me a overshoot factor of 2%-25% when driving a 100pF load.
I have an audio application (2 way active crossover network).
Input: 2x BB OPA 627AP, input frequency limited to 100kHz.
Differential stage: BB OPA 134PA.
24dB/oct, low/high pass.
BB DRV 134 output stage.
All resistors are Vishay non-magnetical. Impedance in this network is below 2kOhm.
I don´t have any stability problem in my network.
Do I have to limit the frequency range in this network directly before the output to prevent overshoot?
