Computed goto problem
Mosaic
Hi guyz , need a bit of help.
I am using a full 512 bytes in a computed goto, so I do the auto update of the PCLATH based on this
movlw High(Table)
        addwf SuboffsetH,W
        movwf PCLATH
        movlw Low(Table)
        addwf SuboffsetL,W
        btfsc STATUS,C ;test if rollover 256 byte page, else skip skpnc
        incf PCLATH,F
Table        addwf PCL,f
              dt      byte,byte,byte,byte etc........
which does the job of rollover.
BUT!!, the addwf PCL,f starts as the first item on a new page boundary and when my goto offset (SuboffsetL) reaches 255. The code hangs on an infinite loop at the addwf PCL,w instruction. If I skip # 255 altogether and bump SuboffsetL to 0 and increment the PCLATH it will continue but SKIP the databyte at location 255.
Can't figure how to get the byte at location #255?
As you have calculated the actual address rather than an offset, it should be,
		movlw	High(Table)
		addwf	SuboffsetH,W
		movwf	PCLATH
		movlw	Low(Table)
		addwf	SuboffsetL,W
		incf	PCLATH,F
......             [COLOR="red"]<-------Edit, there shouldn't be any code here.[/COLOR]
Table		[COLOR="red"]mov[/COLOR]wf	PCL
