How are you planning to attach the components? I doubt that the plexiglass will stand up to soldering temperatures.Has anyone used this conductive ink?
I am designing a small lightweight project that just has 1 red LED 1 smd resistor, a motion detector switch, and a small coin cell battery,
I was planning on drawing a circuit using conductive ink on plexiglass.
Won't that put the adhesive (not copper) in contact with the ink?Planning on using some adhesive-backed copper foil folded over at the ends to contact the conductive ink.
Ahh. Now the plexiglass use makes sense.this project is for earrings that light up.
If you're only running a few milliamps, then 30 gauge is fine.The issue with using 30g wire is maybe its thickness. Not sure
