Configuration Registers Mplab/Junebug
binzer
I have a problem where I can run programs with the Mplab/Junebug combo but the Junebug tutor will not standalone. I know it's not the Junebug and is most likely not setting the correct config registers. If I set them in Mplab will that carry out to the pic when I program it? Is there a good tutorial on the config bits/bytes somewhere. I have done a bit of reading but have not gotten back to trying some of the things out. I did print out the 18F1320.inc file which has some info ( a bit confusing ) but did not find how to set the different clock speeds when using the internal rc osc. Thanks.:confused:
Turn DIP SW 1,2,3 off and the tutor is completely separated from the programmer.
As for the config settings my favorite defaults for MPASM are.
    list    p=18F1320
    include   <p18F1320.inc>
    CONFIG    OSC=INTIO2,WDT=OFF,LVP=OFF
That's a typical header and will select the internal oscillator (it defaults to 31.25kHz)
       movlw   0x62            ; 4MHz OSC
       movwf   OSCCON
And this will get it going at 4MHz, if you want 8MHz use 0x72
Perhaps I'll add this stuff to the Junebug manual.
PS remind me to run it through Pommies PIC code formatter next time :)
Ok, I added that to my little play program.
I compiled via Mplab in release mode, hit start and it runs.
If I switch off 1,2,3 then it still runs.
Power off, with switch 1,2,3 off, connect the power, this should run the program, correct??
I just can't get this to work, what am I doing wrong??
I will post the code here once I figure out how.
Thanks, Mike
Hi Mike,
To get your program to run stand alone you have to select the junebug as programmer - not debugger. When selected as a debugger it downloads the debug exec even if you select the release setting. It appears to be a bug in MPLAB.
test code
; Blue2 Project
	LIST P=18F1320, F=INHX32 ;directive to define processor and file format
	#include <P18F1320.INC>	 ;processor specific variable definitions
;Configuration bits
;;   Oscillator Selection:
	 CONFIG OSC=INTIO2,LVP=OFF,WDT=OFF
;Variable definitions
		cblock	0x01
		d1
		d2
		d3
		endc
;Reset vector
RESET_VECTOR	CODE	0x0000
		goto	Main		;go to start of main code
;High priority interrupt vector
HI_INT_VECTOR	CODE	0x0008
		bra	HighInt		;go to high priority interrupt routine
;Low priority interrupt vector
LOW_INT_VECTOR	CODE	0x0018
		bra	LowInt		;go to low priority interrupt routine
;High priority interrupt routine
		CODE
HighInt:
;	*** high priority interrupt code goes here ***
		retfie	FAST
;Low priority interrupt routine
LowInt:
		retfie
;Start of main program
Main:
	clrf	LATB; clear output latch
	movlw	0x7f
	movwf	ADCON1; set port b for digital inputs
	bcf		INTCON2, RBPU ; turn on soft pullups
	movlw   0x02	;make sure osc is set
    movwf   OSCCON
BURP:
	btfss	PORTB, RB0; check for button #1 pressed
	call BUTT1
	btfss	PORTB, RB2; check for button #2 pressed
	call BUTT2
	btfss	PORTB, RB5; check for button #3 pressed
	call BUTT3
	goto BURP
L1:
LED1 bcf TRISA,0 ; RA0 output
		bcf TRISA,6 ; RA6 output
		bsf TRISA,7 ; RA7 tristate (open)
		bsf LATA,0 ; RA6 High (5V)
		bcf LATA,6 ; RA7 Low (GND)
		call DubDelay
		return
L2:
LED2 bcf TRISA,0 ; RA0 output
		bcf LATA,0 ; RA6 Low (GND)
		bsf LATA,6 ; RA7 High (5V)
		call DubDelay
		return
L3:
LED3 bsf TRISA,0 ; RA0 tristate (open)
		bcf TRISA,7 ; RA7 output
		bsf LATA,6 ; RA6 High (5V)
		bcf LATA,7 ; RA7 Low (GND)
		call DubDelay
		return
L4:
LED4 bsf TRISA,0 ; RA0 tristate (open)
		bcf LATA,6 ; RA6 Low (GND)
		bsf LATA,7 ; RA7 High (5V)
		call DubDelay
		return
L5:
LED5 bcf TRISA,0 ; RA0 output
		bsf TRISA,6 ; RA6 tristate (open)
		bcf LATA,0 ; RA0 Low (GND)
		call DubDelay
		return
L6:
LED6 bcf TRISA,0 ; RA0 output
		bsf LATA,0 ; RA7 High (5V)
		bcf LATA,7 ; RA6 Low (GND)
		call DubDelay
		return
		;bra LED1 ; repeat
		bra Main
;;		END
DubDelay
		movlw	0x50
		movwf	d1
		movlw	0x50
		movwf	d2
Del_1
		decfsz	d1, f
		goto $+4
		decfsz	d2, f
		goto Del_1
 		goto $+2
		nop
		return
BUTT1
	movlw	0x03
	movwf	d3
B11
	call L1
	call L2
	call L3
	call L4
	call L5
	call L6
	decfsz	d3, f
	goto B11
		bsf TRISA,0
		bsf TRISA,6
		bsf TRISA,7
	return
BUTT2
	movlw	0x03
	movwf	d3
B22
	call L1
	call L2
	call L3
	call L4
	call L5
	call L6
	call L5
	call L4
	call L3
	call L2
	decfsz	d3, f
	goto B22
		bsf TRISA,0
		bsf TRISA,6
		bsf TRISA,7
	return
BUTT3
	movlw	0x03
	movwf	d3
B33
	call L3
	call L4
	decfsz	d3, f
	goto B33
		bsf TRISA,0
		bsf TRISA,6
		bsf TRISA,7
	movlw	0x03
	movwf	d3
B34
	call L2
	call L5
	decfsz	d3, f
	goto B34
		bsf TRISA,0
		bsf TRISA,6
		bsf TRISA,7
	movlw	0x03
	movwf	d3
B35
	call L1
	call L6
	decfsz	d3, f
	goto B35
		bsf TRISA,0
		bsf TRISA,6
		bsf TRISA,7
	return
		END
Why not something more like this:
; Blue2 Project
	LIST P=18F1320
	cblock	0x01
	d1,d2,d3
	endc
	org	0x0000
Main	clrf	LATB		;clear output latch
	movlw	0x7f
	movwf	ADCON1		;set port b for digital inputs
	bcf	INTCON2,RBPU	;turn on soft pullups
	movwf	OSCCON
BURP	btfss	PORTB,RB0	;check for button #1 pressed
	call	BUTT1
	btfss	PORTB,RB2	;check for button #2 pressed
	call	BUTT2
	btfss	PORTB,RB5	;check for button #3 pressed
	call	BUTT3
	goto	BURP
L1
LED1	bcf	TRISA,0		;RA0 output
	bcf	TRISA,6		;RA6 output
	bsf	TRISA,7		;RA7 tristate (open)
	bsf	LATA,0		;RA6 High (5V)
	bcf	LATA,6		;RA7 Low (GND)
	call	DubDelay
	return
L2
LED2	bcf	TRISA,0		;RA0 output
	bcf	LATA,0		;RA6 Low (GND)
	bsf	LATA,6		;RA7 High (5V)
	call	DubDelay
	return
L3
LED3	bsf	TRISA,0		;RA0 tristate (open)
	bcf	TRISA,7		;RA7 output
	bsf	LATA,6		;RA6 High (5V)
	bcf	LATA,7		;RA7 Low (GND)
	call	DubDelay
	return
L4
LED4	bsf	TRISA,0		;RA0 tristate (open)
	bcf	LATA,6		;RA6 Low (GND)
	bsf	LATA,7		;RA7 High (5V)
	call	DubDelay
	return
L5
LED5	bcf	TRISA,0		;RA0 output
	bsf	TRISA,6		;RA6 tristate (open)
	bcf	LATA,0		;RA0 Low (GND)
	call	DubDelay
	return
L6
LED6	bcf	TRISA,0		;RA0 output
	bsf	LATA,0		;RA7 High (5V)
	bcf	LATA,7		;RA6 Low (GND)
	call	DubDelay
	return
	;bra	LED1		;repeat
	bra	Main
DubDelay
	movlw	0x50
	movwf	d1
	movlw	0x50
	movwf	d2
Del_1	decfsz	d1, f
	goto	$+4
	decfsz	d2, f
	goto	Del_1
	goto	$+2
	nop
	return
BUTT1	movlw	0x03
	movwf	d3
B11	call	L1
	call	L2
	call	L3
	call	L4
	call	L5
	call	L6
	decfsz	d3, f
	goto	B11
	bsf	TRISA,0
	bsf	TRISA,6
	bsf	TRISA,7
	return
BUTT2	movlw	0x03
	movwf	d3
B22	call	L1
	call	L2
	call	L3
	call	L4
	call	L5
	call	L6
	call	L5
	call	L4
	call	L3
	call	L2
	decfsz	d3, f
	goto	B22
	bsf	TRISA,0
	bsf	TRISA,6
	bsf	TRISA,7
	return
BUTT3	movlw	0x03
	movwf	d3
B33	call	L3
	call	L4
	decfsz	d3, f
	goto	B33
	bsf	TRISA,0
	bsf	TRISA,6
	bsf	TRISA,7
	movlw	0x03
	movwf	d3
B34	call	L2
	call	L5
	decfsz	d3, f
	goto	B34
	bsf	TRISA,0
	bsf	TRISA,6
	bsf	TRISA,7
	movlw	0x03
	movwf	d3
B35	call	L1
	call	L6
	decfsz	d3, f
	goto	B35
	bsf	TRISA,0
	bsf	TRISA,6
	bsf	TRISA,7
	return
	end
Much more readable and easier to work with, IMHO. :) The more code you can see on screen at one time the better. Makes it easier to follow things.
The double labels are weird and unnecessary too, but perfectly legal. Colons are not necessary on labels in this assembler.
I agree, sometimes less is more.:D
Binzer, did you see my earlier post? We posted at the same time and so you may have missed it.
Actually it's not double spaced, not sure why it came out that way. It may not be efficient code, but I'm still getting back to it and learning by adding more stuff and doing things in different ways.
I did not see the post just after mine as I decided to crash, need a little sleep as I have work today also.
I'll go back and check me Mplab settings.
Hi Mike,
Great!! That was the problem. I wonder if it sets by itself when you select the programmer..
Thanks, Mike
I've added the header stuff to the manual, perhaps a debug / release note might be useful too.
How about the OSCON bits also??
;; Use the following to set Oscillator speed in your program
; movlw 0x?? ; where ? is from the following table
; movwf osccon;
;0x72=8mhz
;0x62=4mhz
;0x52=2mhz
;0x42=1mhz
;0x32=500khz
;0x22=250khz
;0x12=125khz
;0x02=31khz
