Hi all,
I have been trying, without success, to use a dpst, to turn remote speakers on or off. The first setup tried was connecting the positive wires from the amplifier right and left channels to the common lugs on the dpst, then connecting wires from the dpst output lugs to both positive speaker binding posts. The negative wires were connected, without interruption, from the amp to the negative speaker binding posts. I used a meter to check the dpst and found both right and left common and output lugs had continuity, in both the on and off position.
I disconnected all wires from the dpst and found the unconnected positive wires had continuity. To reduce work in resolving the problem, I focused on the right channel speaker and disconnected it's positive wire.
I reconnected the amp positive wire to the dpst common lug and the speaker wire to the dpst output lug. The switch worked properly. What caused the continuity problem in the first setup. How do I make this work?
Thanks,
henrylr
Thanks,
henrylr
