kittydog42
Is there any problem with the following:
I am connecting 120VAC main power to a transformer to generate 12VAC. I am then running the 12VAC through a bridge rectifier. I am filtering the rectified DC output across a 220uF 25V cap, then going into a Linear LT1076 switching regulator to generate 5VDC. Can I connect the DC ground out of the regulator to the frame ground of the 120VAC main so that my DC ground and AC neutral have the same potential? Do I do this by grounding the secondary of my transformer?
