Connecting temperature sensor on i2c c18 and ccs
hssn601
Hi All,
i have developed a code to read temperature but its not working please help to correct it.
Sensor Model:am2315
Sensor info:
#include <18f4525.h>
#include <stdlib.h>
#fuses INTRC_IO, NOWDT, PUT , BROWNOUT, NOLVP, NOPROTECT, NOMCLR
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use i2c(master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
unsigned char rx_byte;
unsigned char rx_byte1;
void main(void)
SET_TRIS_A(0x00);
int a=0;
while (a<2){
output_high(PIN_A1);
delay_ms(500);
output_low(PIN_A1);
delay_ms(100);
a++;
while (1)
printf ("Start i2c \n");
i2c_start();
delay_ms(50);
i2c_write(0xB8);  /* Device Address */
delay_ms(50);
i2c_write(0x03);
delay_ms(100);
// reading humidity
rx_byte = i2c_read(0x00);
delay_ms(50);
rx_byte1 = i2c_read(0x01);
delay_ms(50);
printf ("rx_byte1 = 0x%2.2X\r  0x%2.2X\r \n", rx_byte, rx_byte1);
//read temp
delay_ms(50);
delay_ms(50);
printf ("rx_byte1 = 0x%2.2X\r\n", rx_byte1);
i2c_stop();
printf ("End\n");
  • AM2315.pdf
Why c18 and CCS? I dont understand what you mean by that
Ok i see now you didnt mean C18 but 18F :D
You are not reading for multiple reads... Read the manual for streaming multiple bytes or write a wrapper function to grab one byte at a time
C:
i2c_start();
i2c_write(0xB8);
i2c_write(0x3);
i2c_start();
i2c_write(0xB9);
data1 = i2c_read(TRUE);
data2 = i2c_read(TRUE);    // Keep this high until you read the last byte
data3 = i2c_read(TRUE);
data4 = i2c_read(FALSE);  // this tells the slave to stop sending!!
i2c_stop();
