PedroV
I bought a Ramsey Electronics FM transmitter kit.
The whip antenna is attached to the circuit board with a screw. The antenna that I have has a joint so it can be bent at an angle. but because of the length of the joint and size of the enclosure, you cannot actually bend the joint. I know nothing of antennas. Can I mount antenna to the enclosure and connect to the circuit board via a simple wire? Are there any considerations?
