I am working on a simple automation project. I will require some type of motor (likely stepper) to fairly precisely index positions, hold that position for a variable amount of time, then index again and continue that.
I have found simple geared steppers and control boards on ebay cheap but I have NO idea how they are being controlled. I am very familiar with CNC machines so I know sort of how the stepper works. I would reach for a servo motor just for more familiarity but that is likely WAY overkill for this and a stepper seems the right choice here. .5* index accuracy will work fine for this.
I do not require any rotational torque other than that to overcome friction. I am, however, a bit concerned about "skipped steps" that seems common in stepper tuning during accel or deceleration. I do not really want to hassle with encoder feedback.
I would also consider other indexing ideas rather than the stepper. That just came to mind.
EDIT: I should add that one hurdle and issue with this is I need something that will possibly be current limited so if something stalls the rotation, it will not destroy itself. Also, there is likelihood that something will stall the rotation and I need to figure out a way to get the motor back into correct position, add feedback so the motor will know it did not rotate enough due to obstruction, or add some type of "in position" signals at each index directly. I guess in that respect, I could just use a basic motor and have the power turn off when in position.
