Control of digital servo different from analogue servo?
king.oslo
Hello there,
I made a device that controls a analogue servo using a PIC18 microcontroller. I used variable pulse width to control the angle of the servo. The pattern was like this:
SIGNAL (1-2ms) --- PAUSE (20ms) --- SIGNAL (1-2ms) --- PAUSE (20ms) --- SIGNAL (1-2ms)
I recently bought a digital servo. A HiTec-branded one, and it doesnt seem to respond to this pattern. This makes me wonder if that servo requires a different signal because it is digital?
Thanks.
Kind regards,
Marius
It should respond the same as the analog servo, with digital servo's the only thing that changes is how things work under the hood, the steering commands are still the same. The term 'digital' servo is a bit of a misnomer, it's an industry term used only because the control electronics are different. The original analog servo's were still digital in nature, it's pulse length modulation, but with restrictions on duty cycle. They're still tehcnically digital devices because they rely on on and off pulses, even if all the electronics under the hood are analog.
Digital/Analog is actually not as clear cut to describe as you might think.
