Hello all,
I am trying to connect my pc to a 220V circuit. The final idea is to have a (winamp) plugin control my parallel port output, to connect that through a solid state relais to a 220V system so that I can have disco lights.
I successfully made a circuit like that with a conventional relais (see below for picture)... but the clicking noise is annoying...
I have a S202S02 (.pdf!) solid state relais. Can I use it? If so, how? Simply replacing the relais with my SSR doesn't seem to do very much, but I don't understand why. I did read the available documentation (or, all I could find)... but frankly I don't even understand what voltage I need to make that SSR conducting. The documentation .pdf mentions Electro-optical Characteristics: Forward voltage: typ 1.2 V, max. 1.4 V. Does that mean that I shouldn't put more than 1.4 V across the DC part of the S202S02?
Uncertain as a proper newbie I feel I probably oversimplified the working of a SSR (I see it as a noiseless normal relais).
This is the circuit I used when I had a normal relais. LPT is the Parallel port of a PC, and "input / output" is the high voltage (220 V) side.
