if you want to measure AC amps in do the same with a resistor but retify it before applying it to a pic, i beleive an opamp circuit can provide voltage dropless rectification. I have to say your requests are not entirely clear
If you want to safely measure the current and voltage in the 220VAC circuit then you will need two transformers, a voltage transformer across the line and a current transformer in series with the load. The outputs of these can be rectified to give a DC representation of both.
