Converting CCS to XC8
Muscleman
Hello people, I'm doing a project based on this one:**broken link removed**
but then the code provided by the author is based on ccs, but i need to convert it to xc8
here is the code
#include <16f877a.h>
#include <defs_877.h>
#use     delay(clock=10000000)
#fuses   hs,nowdt,nocpd,nolvp,noprotect
#byte portb=0x06
#byte portd=0x08
#bit  clock=portd.6
#bit  data=portd.7
unsigned int8 i,j,index1,n,
addr[11]={0xEA,0xEA,0x2A,0x2A,0x2A,0x2A,0xAA,0x82,0xFF,0xFF,0xFF},
cont[11];
void main()
     set_tris_b(0x00);
     set_tris_d(0x00);
    while(1)
        for(n=0;n<=99;n++)
            data=1;
            for(i=0;i<=7;i++)
                clock=1;
                portb=addr[i];
                delay_ms(1);
                clock=0;
                data=0;
        for(j=0;j<=10;j++)
            cont[j]=addr[j];
        for(j=0;j<=9;j++)
            addr[j]=cont[j+1];
        addr[10]=cont[0];
here is my attempt at converting to xc8
#include <xc.h>
#include <htc.h>
#include <stdint.h>
#pragma config WDTE=OFF
#pragma config LVP=OFF
#pragma config PWRTE=OFF
#pragma config DEBUG=OFF
#pragma config FOSC=HS
#define __delay_ms(x) _delay((unsigned long)((x)*(_XTAL_FREQ/10000000.0)))
#define   _XTAL_FREQ 10000000
int main(void)
uint8_t i,j,index1,n,
cont[11];
     TRISB=0x00;
     TRISD=0x00;
    while(1)
        for(n=0;n<=99;n++)
          PORTDbits.RD7=1;
            for(i=0;i<=7;i++)
               PORTDbits.RD6=1;
                PORTB=addr[i];
                __delay_ms(1);
                PORTDbits.RD6=0;
                PORTDbits.RD7=0;
        for(j=0;j<=10;j++)
            cont[j]=addr[j];
        for(j=0;j<=9;j++)
            addr[j]=cont[j+1];
        addr[10]=cont[0];
I'm not sure how to convert
#byte portb=0x06
#byte portd=0x08
#bit clock=portd.6
#bit data=portd.7
I would appreciate some help thanks.
Just remove these.
Note that the original programs sets D6 at the beginning of the inner loop while you set D7.
ok thanks, about the other statement or my conversion of data=1 or 0 to PORTDbits.RD7=1 or clock=1 or 0 to PORTDbits.RD6=1 is it correct? because I uploaded to the program to my pic (actual circuit) but the dot matrix shows only blinking lights
Yes. The original program is setting data (D7) to 1 for the first execution of the inner loop and to 0 for the rest of them, and cycles the clock (D6) every loop. Is that what you're trying to accomplish?
Yes sir, I just based it on the original program of the author, other than that are there any flaws in my conversion that could not make the desired output( driving dot matrix)?
Aside of these lines, not present in the oringinal:
C:
PORTB=0x06;
PORTD=0x08;
which are not harmful, and the fact you set D7 instead of D6 in the inner loop, the programs look identical to me.
C:
PORTB=0x06;
PORTD=0x08;
Ooops, I just noticed I set d7(data)=1 instead of d6(clock)=1 in the for i loop:facepalm: , I edited the code now to which I removed:
PORTB=0x06;
PORTD=0x08;
edit:I had included earlier that code^ because i thought I would convert this one also:
#byte portb=0x06
#byte portd=0x08
Thanks so much for help!! :) it's now working in the proteus isis simulation, all I have to do now is connect it again in the actual circuit, but tomorrow is the day I can test because someone's taken care of the pcb development today
