hentai said:House0Fwax thx for the reminder, i always forget to search first before i open a new thread. The pressure sensor solution seems simpler but I'm wondering if its as precise as measuring velocity.
i see but wouldn't the sensor's output be proportional with momentum?Ron H said:A velocity sensor will no measure momentum (the mass times the velocity)
Only if the mass is constant. If you are testing the punching ability of one person, then that will work. If you are testing a wimp against a heavyweight boxer, then it won't.hentai said:i see but wouldn't the sensor's output be proportional with momentum?
I got the picture now... thx for the tip.Ron H said:Only if the mass is constant. If you are testing the punching ability of one person, then that will work. If you are testing a wimp against a heavyweight boxer, then it won't.
