Transistorman
after i download pdf file that eric give to me in using ADC input of PIC12F629
i starting to converting the code using mplab
but after pressing quickbuild button , the build always failed
error
please tell me how to fix it ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
error
Release build of project `C:\Documents and Settings\Mimi\Desktop\Asm and C file\BSC.disposable_mcp' started.
Language tool versions: MPASMWIN.exe v5.33, mplink.exe v4.33
Tue Aug 10 23:33:12 2010
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p12F629 "BSC.ASM" /l"BSC.lst" /e"BSC.err"
Warning[207] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 1 : Found label after column 1. (listp)
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 3 : Found directive in column 1. (errorlevel)
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 4 : Found directive in column 1. (radix)
Warning[207] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 5 : Found label after column 1. (__CONFIG_MCLRE_OFF)
Error[108] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 5 : Illegal character (&)
Error[108] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 6 : Illegal character (&)
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 8 : Found directive in column 1. (UDATA_SHR)
Error[149] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 8 : Directive only allowed when generating an object file
Error[108] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 9 : Illegal character (1)
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 12 : Found directive in column 1. (banksel)
Error[152] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 12 : Executable code and data must be defined in an appropriate section
Warning[203] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 14 : Found opcode in column 1. (movlw)
Error[113] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 14 : Symbol not previously defined (nLED)
Error[152] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 14 : Executable code and data must be defined in an appropriate section
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 15 : Found directive in column 1. (banksel)
Error[152] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 15 : Executable code and data must be defined in an appropriate section
Error[108] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 17 : Illegal character (<)
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 18 : Found directive in column 1. (banksel)
Error[152] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 18 : Executable code and data must be defined in an appropriate section
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 22 : Found directive in column 1. (banksel)
Error[152] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 22 : Executable code and data must be defined in an appropriate section
Error[108] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 23 : Illegal character (,)
Error[108] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 24 : Illegal character (,)
Error[108] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 25 : Illegal character (,)
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 26 : Found directive in column 1. (banksel)
Error[152] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 26 : Executable code and data must be defined in an appropriate section
Warning[205] C:\DOCUMENTS AND SETTINGS\MIMI\DESKTOP\ASM AND C FILE\BSC.ASM 29 : Found directive in column 1. (END)
Halting build on first failure as requested.
Release build of project `C:\Documents and Settings\Mimi\Desktop\Asm and C file\BSC.disposable_mcp' failed.
Tue Aug 10 23:33:13 2010
BUILD FAILED
