counter with negative output
inabox
Hi a newbie here, i need something like a 4017 or BCD counter, but the outputs need to be V- (ground) instead of V+, thanks for the help
Use a 4017 and 2 inverters.
The correct term is active low not V-.
The 4017 has active high outputs so an inverter will make it active low.
Don't forget to connect the inputs of the 2 unused inverters to ground.
