X
xl5
Guest
Bought from auction complete with fault, stated as no signal separation or signal display.
Switching on only one trace is visible but can be moved vertically and horizontally with say the ch1 controls but using ch2 also moves this single trace. Is the second trace generated from the first trace ?.
Anyhow taking the cover off and inspecting the main pcb i noticed immediately a new 0.25W resistor that had been soldered at one end only the other leg in the air! it being obvious the original resistor that lived their had been snipped out and this new resistor soldered to one end of the protruding pigtail, This resistor (R3) had a value of 0.68 omn's (safety resistor?) i then had the temptation to solder the other resistor leg into place but decided against this as a little scorching was present where the original had been roasted!.
The moral of this tale is: I need advice i also need a cct diagram to further investigate this fellows fault so can anyone here help so that other trace can be restored![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
