Crude assembly counter
I want to run a routine seven times. Would something like this work?:
Counter equ 20   ; variable to put the counter in
   ; Main code here.
   ;  At some point it'll call RoutineName
RoutineName
   movlw b'01111111'
   movwf Counter
RoutineLoop
   Goto Transmit          ;  this being the routine to be done seven times
   RRNFC Counter,1     ; roll the bits right, don't use carry, store result in counter?
   BTFSC Counter,1     ; check counter.  skip next  line if it's clear?
   Goto RoutineLoop     ; repeat loop if there are still bits in Counter
   Return  ;  if there are no bits in Counter return to where RoutineName was called
I'm not sure about my use (and understanding) of RRFNC. also am i checking the lsb using BTFSC COunter,1 ?
Any suggestions appreciated..
Mark
What's RRNFC?. Assuming this is PIC assembler, bits go from 0 to 7, so the least significant bit would be 0, not 1.
If you want to see how loops are done, have a look at my PIC tutorials, many of those use loops.
DECFSZ is best for loop counting.
   ; Main code here.
RoutineName
   movlw 7
   movwf Counter
RoutineLoop
   CALL Transmit          ;  this being the routine to be done seven times
   DECFSZ Counter,f
Thanks for the help. I see now how complicated i was trying to make it!
20ff RRNCF f,d
Rotate right (no carry)
(found it in the MPLAB help files)
Remeber ASM is very specific, its best when asking for help that you clearly say what device you are using, the fuse settings, as well as a breif overview of what the final application will be.
Low end microcontrollers, been developed in ASM, don't deal very well with the idea of box design, where you don't care about other peoples code to be run on the same micro.
