I am doing a project where around 750mA is needed, how can I amplify the current while maintaining the voltage.
Answer the questions in blue and we may understand what you are trying to do sufficiently to be of help.I am doing a project where around 750mA is need (from what source?), how can i amplify the current (to what value of current?) while maintaining the voltage (what voltage?). I read a forum that said i should use a Darlington transistor, is this correct? And if so how would i do so?
Amplify what current?how can i amplify the current
I am trying to charge my phone from a nine. Volt. Battery using a 7805 and usb jack. It works Just a lot slower due to the low current, the voltage now is at 5.1v and the current at about 150 mA. Now is possible to use a op amp or transistor?
The IC drives the inductor with a square-wave signal. The square-wave turns on and off and on and off etc.How does the mintyboost work? I followed the link and it didn't say how ot show a schematic.
