madmikejt12
Hi, I would like to lower a current from 15-17A to around 200mA is this possible, cheap and easy to do?
thanks,
Mike
thanks,
Mike
madmikejt12 said:it was the speaker outputs i put it across (+connection and -connection)
the current was from the speaker output from the cd player, not the power supply, it is different isnt it? If i connected an LED with current limiting resistor, the LED would blow wouldnt it?
madmikejt12 said:if its the voltage i need to know, but cant measure it..... does this mean that i can either risk it or not try it?
is it safe to put a large resistor and an LED directly to the amplified speaker output?
it says on this PDF i have:Use ohms law - presumably you know the claimed output of the amplifier? (which will probably be far higher than it actually is), and the speaker imedance - it's simple to calculate the peak or RMS output voltages.
Using a bulb is probably the better idea. However, they're tricky in that a cold filament is a dead short. After you apply power and let it heat up this resistance goes to a safe resistance range, though it's different from bulb to bulb. You'll have to guard against that. Perhaps you need to apply a small "startup" current to preheat the filament while isolating the amp from it. Or, better yet, put a power transistor to drive the bulb. This largely isolates the amp's output from the bulb, but not entirely.
The DC output of each output wire is about 6.5V. So your transistor would be turning on the light bulb all the time, and the bulb will flicker at the audio frequencies which is too fast to see any variation.madmikejt12 said:Thanks is it used like a normal transistor where the input goes to the base, the device (bulb in this case) goes from the +Ve to collector and the emiitor to 0v??
and I presume I would need one for each output?
Would the attatched circuit work?
