Hi all,
I'm busy trying to repair a monitor (you might have seen my earlier posting on the GND point where I almost blew myself up
and have a few questions I hope someone can answer. Its a long one so please bear with me.
When powering on the monitor the voltages on the PSU board keep rising and falling and the relay for the degaussing keeps clicking - presumably from the rising and falling voltages. I've ripped the PSU board out and am working on it separately.
I've attached the circuit diagram I found:
I thought I found the problem which was with IC601, a UC3842, a current mode regulating PWM. (The red circle on the diagram) If i disconnect the Vcc from the chip the voltage is stable at 30V, reconnecting the pin causes the voltage to climb to 15V and then suddenly drops to 10V. It rises again to 15V in a seconds and drops again etc etc
I've also tried disconnecting all the pins except GND and Vcc and the problem still occurs - hence why I thought it was faulty. I've now replaced the chip and also the 15V zener (D604) which I also thought might be faulty.
Since the new chip does the same thing I presume there's nothing wrong with it and rather something else is causing it. Unless my logic is completely of course here.
Here's a link to the PWM:
https://www.electro-tech-online.com/custompdfs/2007/07/IP1842_3.pdf
Now onto my question (finally) - has anyone used the above chip before, is it supposed to exhibit the above symptoms I described and am I look completely down the wrong path for the problem?
I know I could take the monitor in for repair, but I'd like to repair it myself and learn as much as possible in the process - and now its become an obsession to fix it as well!
