DAC output
chandu13
Hay every body
How to control the 0-24v(500mA) proportionally with 0-5V micro controller
DAC output
Thank you
Regards
Hay every body
DAC output
Thank you
Regards
You could use a MCP4922 dual 12bit DAC , SPI connection.
Requires a volt/current amp on the DAC output.
Here is how you can control an adjustable voltage regulator from a DAC.
The control inputs of voltage regulators is usually 1.22 volts or so, and you can get 0 - 24 volts out for 5 - 0 V in with suitable choice of resistors.
The output goes up when the DAC output goes down so you have to reverse the signal in software.
In some cases, you can skip a DAC completely and use PWM. It depends on what you are controlling.
