Daewoo dlp-37d1
Edmond
Hi!
I'm looking for schematics or SM for the DAEWOO DLP-37D1 LCD TV. The set does not switch on, the front LED is dark. The PS board is PV-LT280037DD.
Thanks for help.
Start checking parts, fuses etc. You should first check the capacitors to see if they are bad (bulging top, leakage).
daewoo 37
check this out and see if it works for you.
  • DAEWOO+DLP-26C2,26C3,32C1,32C2,32C3,37C3,42C1+Chasis+SL-223P.pdf
