Dancing fountain
Mike_2545
Super Moderator
I have completed a fun project that shoots "pulses" of water around a pond inside a greenhouse. The water pulses jump from one spot to another, there are 12 solenoids connected to a micro controller. The circuit is simple,the micro controller turns on a 2N2222 transistor, the transistor drives a 5 volt relay and the relay turns on the solenoid. Times 12.
I put a motion sensor on the unit so it only operates when someone is around to see it. I programed a Basic Stamp micro controller to run 5 separate valve sequences in a random order.
Here is a link to a video I shot just after installation. If you look close you can see my assistants leg triggering the motion sensor.YouTube - Dancing water feature
Enjoy
  • Jumping frog Flow chart.pdf
  • Transistor relay circuit.pdf
Interesting application mike, nice construction. A good example for a basic stamp.
Do the selonids feed city water or recirculated pond water ?
If you are using city water (or well) you could add a water level sensor and use the setup to keep the water level up.
I like it.
3v0
3v0,
The solenoids feed city water at about 50 psi. I was worried about recirculating the pond water, for fear it would gunk up the valves.
It does help fill the pond, which we did have to do weekly.
I did have to add a water hammer arrester, basically a tank with an air bladder, to absorb the shock of when the solenoids turn off.
Valves and jets
What size/type/model of solenoid valve did you use? Also, what did you use for the jet/nozzle?
I picked up some solenoids from e-bay, they are 24vdc and have 1/4" threaded connections. Most solenoids will handle air or water, check the manufacutrer specs to be sure. The Nozzle is just a piece of 1/4" copper tubing.
