cheap&simple
I need a cheap&simple day /night sensor that is not a power hog to give a input to a microchip.
thanks![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks
cheap&simple said:I need a cheap&simple day /night sensor that is not a power hog to give a input to a microchip.
thanks![]()
Depends on the battery and current consumption of the circuit...not sure how hard its going to be on the batteries.
The puny 0.2V to 1.5V from an ohm-meter won't power an entire circuit enough to give an indication of its "resistance" nor its current draw.mstechca said:You could probably measure the resistance of the entire circuit with a ohmmeter (DMM set to the ohms function).
Once you get that, use ohms law to get the current being consumed by the circuit.
Convert your current into mA.
