DC adapter vs Battery
Njguy
I wanna eventually use a 12 volt battery for my application, but while its in development I have no desire to be messing with one. Recharging it and such. So I figured I would get a 12v DC adapter that plugs into the wall. Like the one here. **broken link removed**
My question is about the plug. If I were to cut off the plug/connector would there be two wires inside, like for positive and negative? Or if I could somehow buy the female end and save the connector.
If the plug has two contacts, then the cable should have two wires.
Whether to cut the wire or use a connector depends upon what else you may want to use the adapter for.
It can be handy to be able to unplug the power supply during testing so I would recommend getting the matching socket if it isn't too difficult to find.
That also would allow you to easily change between the adapter and battery as a power source. You may find that your application doesn't always work the same under adapter power as it does under battery power so being able to readily change back and forth can be helpful.
This is a very noobish question. I bought this power jack- Alectron - ZC-2550A - Allied Electronics
As you can see from the picture it has 3 unmarked prongs. I cannot seem to figure out what the 3rd one does. I know with my multimeter, I will not get the full voltage unless the ground probe on the meter touches two of the prongs at once. Any help?
You bought the wrong jack. It is made to mate with a 2.1mm plug but the power supply has a 2.5mm plug.
The third terminal on the jack is the switched contact that would allow a battery to power the device then disconnects the battery when the power supply is plugged into it.
Ahh well it fits perfectly so I don't see how it can be the wrong one.
A 2.5mm plug does not fit in a 2.1mm jack. One of the numbers is wrong or the parts got mixed up if it fits perfectly.
I think, that you're mixing up two sets of numbers. One is inner bore, and the other is outer bore. Both have an inner bore of 2.1 mm and an outer bore of 2.5 mm.
Both of you are almost right. In both cases the outer cylinder is 5.5mm. The 2.1mm jack appears to perfectly fit the 2.5mm inner bore, but there's 0.4mm of total clearance which will sometimes connect and sometimes not connect.
MODE Electronics sell 2.1mm plugs and jacks and 2.5mm plugs and jacks.
The wrong one does not fit into the wrong one or they are too loose:
