orkeet said:i want this circuit using ac voltage input and still can work as darkness detector. i've tried to replace the dc voltage with ac voltage but it seems like the circuit doesn't work as darkness detector anymore. i think the circuit needs some modifications but i can't figure out what it is. i still need two op amp in my circuit.i'm still new in this design thing.
h.d said:youonly need to add the suitable rectifier after the ac input to get the needded dc-voltage value,so you need only rectifier
orkeet said:yes. this is a school project. my lecturer wants a circuit that use two op amps or three transistors. after i showed him the circuit which use dc power source, then he wanted it in ac mode. i've thought about adding a rectifier but i just want your opinions that maybe there is other way to change this circuit to ac mode. so i guess i just have to add a rectifier to the circuit.
thank you very very much for your opinions![]()
