I will run 2 small dc motors on a little bot im building ...
i already used standard caps noise reduction , 1 cap (0.1uF) across motor terminals and 2 others from the terminals to the motor casing ...
noise level is not bad but i still can see a bit of it.
is grounding the casing of motor to a common ground with the power battery be a good think / good practice ?, fast silly tests don't seem to show any difference ( im running 2 different sets of batteries for motor and controller ...
im thinkink to have shielded cable to motor this might be where noise spread...
any others good practice, advise ?
