DC motor parameters
dmta
Hi everyone !!!!!!!
I am working on a DC motor control project in which I need certain motor parameters such as torque constant, inertia, resistance, inductance etc (all constants needed to model and write DC motor equations).
Can you please help me !!!!!!!!!
Regards
I would suggest you contact the motor manufacturer.
Hi crutschow, thanks for the reply !!!!!!!
I'm afraid the motor does not have a part number or a manufacturer name.
Then there is no other option than trying to measure the parameters yourself. Resistance and inductance is fairly easy to measure (stall the motor and measure with multimeter/oscilloscope). K parameter is the second easiest to measure (or estimate), because it is directly proportional to the motor speed at unit voltage (steady state gain of the transfer function).
I would suggest (if you really need the parameters) that you try to measure the step response of the motor and figure out the transfer function. It should be a second order transfer function (attached).
Tutorial:
https://www.facstaff.bucknell.edu/mastascu/econtrolhtml/Ident/Ident1.html
